[Gdal-dev] Mrs ID driver for VC7
Chapman, Martin MChapman at sanz.com
Fri Apr 23 03:52:44 EDT 2004
Andrey,
Thanks for the response.  I finally figured out how to link to mrsid, and thanks to the code update provided by Bjoern everything built ok.  Now I am getting the error "not recognized as a supported file format".  So I need to know where to set that option.
Thanks,
Martin
	-----Original Message-----
	From: Andrey Kiselev [mailto:dron at ak4719.spb.edu]
	Sent: Fri 4/23/2004 12:30 AM
	To: gdal-dev at remotesensing.org
	Cc:
	Subject: Re: [Gdal-dev] Mrs ID driver for VC7
	On Thu, Apr 22, 2004 at 04:14:28PM -0600, Chapman, Martin wrote:
	> I have a thirty day trial of the Mrs. Id driver for windows VC++
	> Version 7.  How do I link it to the GDAL lib?  Are there instructions
	> somewhere on how to do this?  I also read on the user group that there
	> may be issues with the V7 driver from Lizardtech and GDAL because GDAL
	> was written to bind to the VC6 version of the mrsid lib.  Is this an
	> issue?
	It is all the same for GDAL what compiler version will be used, bacause
	GDAL comes with full source code. It is completely defined by the DSDK
	binaries you have which you can't rebuild. The main problem is in API
	version. GDAL currently supports MrSID DSDK 3.1.x and 3.2.x. Newest
	version (4.0) are not supported yet due to completely different API.
	> I am using GDAL 1.1.9.
	There are was few fixes in that driver in GDAL 1.2.0.
	                                                Andrey
	Andrey V. Kiselev
	Home phone:  +7 812 5274898  ICQ# 26871517
	Gdal-dev mailing list
	Gdal-dev at remotesensing.org
	http://remotesensing.org/mailman/listinfo/gdal-dev
