[Gdal-dev] Reprojection a GeoTIFF heightMap
StefanReisser at t-online.de StefanReisser at t-online.de
Fri Aug 13 16:47:37 EDT 2004
when trying to reproject a heightMap from UTM 10 / WGS84 to UTM 10 /
NAD27 I get the error message:
ERROR 4: 'fileName.tif' not recognised as a supported file format.
followed by a bus error.
The heightMap itself should be fine, so I wonder where the problem might
be. Is it just not possible to convert between the different datums?
Help is appreciated!
Thanks and kind regards,
Stefan
