[Gdal-dev] Conversion to Grayscale
    Chris Hodgson
    chodgson at refractions.net
    Fri Dec  3 14:17:18 EST 2004
Yes, these are full color images and I would like a reasonably "correct"
grayscale representation.. I somehow got the notion that simply
averaging the RGB values would do this... but that sems to be wrong
based on what Paint Shop Pro does... I don't know much about colorspace
transformations... all I know is that it shouldn't take as long as
imagemagick 'convert -colorspace gray' does.
My current problem seems to be that I can't get gdal-python to compile
(see my next post).
Chris
>Chris,
>Do you want a "proper" RGB to greyscale conversion or is
>it sufficient to just take any one of the bands and use it as
>greyscale?  I believe a "proper" conversion would involve
>a colorspace transformation on the RGB image into IHS or
>something like that, and then taking the intensity.  This is
>not conveniently available in GDAL but could be implemented
>in Python.
>However, if the file is really just a greyscale image represented
>in RGB then you could use the -b switch to pick out one band
>from the source image to use as the output greyscale image.
>eg.
>gdal_translate -b 1 in.tif out.tif
>Best regards,
