[Gdal-dev] Problems building gdal dll with libtool on MinGW
Mario Beauchamp starged at videotron.ca
Wed Feb 18 01:06:58 EST 2004
Hi Andrey,
On Tue, 17 Feb 2004 10:15:37 +0300, Andrey Kiselev <dron at ak4719.spb.edu> wrote:
>We don't need to link with libm when compiling with MinGW. This problem
>was fixed few weeks ago.
Noted.
>> And if I understand libtool correctly (don't bet on that!), a dll
>> created with libtool needs libtool to link, right?
>No, it can be the drop-in replacement for gdal.dll, compiled with the
>MSVC. The only problem here is a C++ name mangling.
Well, I solved the problem: I built a "mini" GDAL static lib in Dev-Cpp (ie with no libtool, with
only a few drivers and not using the makefiles generated by configure) and will make a dll out of it
later using the a2dll script that comes with MinGW. As the author puts it:
"Also, until GNU libtool will allow seamless building of Win32 DLLs, you may build static lib (what
libtool of course supports) and then convert it to DLL"
Thanks for your support.
Mario B.
My Landsat images:
http://pages.infinit.net/starged/landsat/home.html
