[Gdal-dev] Implementing GDALRasterBand::IRasterIO
James Gallagher jgallagher at gso.uri.edu
Wed Jan 14 12:21:15 EST 2004
I would like to add sub-sampling capabilities to the OPeNDAP/GDAL
driver. To do this I plan on specializing GDALRasterBand::IRasterIO().
First question: is that method the correct place to implement
sub-sampling?
Second question: I noticed that the OGDI driver implemented only the
GDALRasterBand::IRasterIO method while the ECW driver implemented it's
own version of both that and GDALDataset:IRasterIO. What are the
implications of specializing the second method?
Thanks,
James
__________________________________________________________________________
James Gallagher		         The Distributed Oceanographic Data System
jgallagher at gso.uri.edu               http://unidata.ucar.edu/packages/dods
Voice/Fax: 406.723.8663
