[Gdal-dev] gdal config icluding xerces
Fri Jul 9 10:48:59 EDT 2004
Daniel Isenegger wrote:
> Hi
> i have installed grass57 on suse9.1 and want to use gdal for the
> grass-commands v.in.ogr and v.out.ogr. When applying v.out.ogr xerces is
> needed by gdal.
> when compiling gdal to use xerces i get the following errors (2
> different tries in the following):
> - when using xerces 2.1.0 (built from source):
> ./configure --with-grass=/usr/local/grass-5.7.0
> --with-pg=/usr/local/pgsql/bin/pg_config --with-xerces
> --with-xerces-inc=/downloads/xerces/xerces-c-src2_1_0/include
> --with-xerces-lib="-L/downloads/xerces/xerces-c-src2_1_0/lib -lpthread"
> --with-odbc=/usr/local/lib --with-static-proj4=/usr/lib/libproj.so | tee
> configure_disen.log
Daniel,
I tried this out and found I had to do things a bit differently:
   ./configure --with-xerces --with-xerces-inc=/u/pkg/xerces-c-src2_2_0/include/xercesc
--with-xerces-lib="-L/u/pkg/xerces-c-src2_2_0/lib -lxerces-c -lpthread"
Note:
  o the include directory is <base>/include/xercesc, not just <base>/include.
  o The lib directive needs to include the library (-lxerces-c) as well as the
    path and pthread.
With this it worked for me.  In general though I find it much easier to just
"make install" xerces and use --with-xerces alone to find the library.
Best regards,
