[Gdal-dev] Kakadu float rasters and 16bits lossless
Fri Jul 16 12:01:11 EDT 2004
Julien Demaria wrote:
> Frank,
> sorry I've just seen in the source this comment (and thought the
> documentation was outdated...) :
>  * Revision 1.20  2004/01/15 21:21:04  warmerda
>  * added lossless compression of 16bit values
> but haven't verified that... (a little test with diff seams fails...)
> Other question :
> I searched on gdal web sites for a CVSWeb ; is it disabled ? (I've found
> only http://www.remotesensing.org/cgi-bin/cvsweb.cgi/osrs/gdal/ on
> http://gdal.maptools.org/download.html but it doesn't works...)
Julien,
I haven't setup cvsweb on the new remotesensing.org.  I'll remove it from
the download.html.  Moving machines has been a huge hassle.
Best regards,
