[Gdal-dev] ogrinfo -sql doesn't work with GML files?
Tue Jul 20 13:33:34 EDT 2004
Tyler Mitchell wrote:
> I can't seem to get ogrinfo to reduce my set of features in a GML file
> using the -sql or -where parameters.  Should this be expected?  It doesn't
> fail, but still returns the full set.  I've tested this using openev_fw
> (windows) and a nightly build of gdal from yesterday (linux).
Tyler,
I checked, and sure enough, I never implemented the spatial or attribute
query capability in the GML driver.  I have incorporated it now in CVS.
>>ogrinfo airports.gml -sql "select name from airports where quadname like
> '%Lake'"
> Works great on shapefiles!
> Tyler
> p.s. Bugzillla down?
Yes, bugzilla is still inaccessable unfortunately.
Best regards,
