[Gdal-dev] OGR and OGDI issues
Markus Neteler neteler at itc.it
Thu Jun 24 06:21:17 EDT 2004
At time I am facing some problems with OGR/OGDI:
I have updated to
- the current OGDI-CVS
- the current GDAL/OGR-CVS
- Mapserver 4.2.
Following three problems occured:
1) OGDI compiled with external PROJ fails:
  ogr2ogr -t_srs "EPSG:4326" -where "na2 = 'UP'" polbnda_ukraine.shp \
       gltp:/vrf/grass0/warmerdam/v0eur/vmaplv0/eurnasia 'polbnda at bnd(*)_area'
  ERROR 6: Failed to initialize PROJ.4 with `+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs '.
  unknown projection id
  Failed to create coordinate transformation between the
  following coordinate systems.  This may be because they
  are not transformable, or because projection services
  (PROJ.4 DLL/.so) could not be loaded.
  Source:
  GEOGCS["NAD83",
    DATUM["North_American_Datum_1983",
        SPHEROID["GRS 1980",6378137,298.257222101,
            AUTHORITY["EPSG","7019"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6269"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AXIS["Lat",NORTH],
    AXIS["Long",EAST],
    AUTHORITY["EPSG","4269"]]
  Target:
  GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    UNIT["degree",0.01745329251994328,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","4326"]]
 It is not clear to me if OGDI or OGR is doing the
 reprojectioning.
 With OGDI compiled with internal (old) PROJ support it
 works. But then it won't do datum transformation, right?
 So far I don't know how to get that working. Any hint
 is appreciated.
2) A related problem: Some field in PostgreSQL seems to be too
   short? I tried to convert VMAP0 data via OGR to PostGIS.
   After a while I got
  ogr2ogr -f PostgreSQL PG:'host=localhost user=postgres dbname=vmap0' \
    gltp:/vrf/grass0/warmerdam/v0eur/vmaplv0/eurnasia \
    -nln polbnda 'polbnda at bnd(*)_area'
  ERROR 1: INSERT command for new feature failed.
  ERROR:  value too long for type character(64)
  ERROR 1: Terminating translation prematurely after failed
  translation of layer polbnda at bnd(*)_area
  Where should I change the field length?
3) Finally, sorry for being so lengthy, MapServer gives following
   error with OGDI-Data (it works well with SHAPE and raster):
   msDrawMap(): Image handling error. Failed to draw layer named 'roadl_africa'.
   msOGRLayerInitItemInfo(): OGR error. Invalid Field name: rtt
  Since the mapfile [1] is unchanged which worked well before updating
  the software it seems to be related to OGR (I tried Mapserver 4.0 and 4.2).
  But:
  export OGDI="gltp:/vrf/grass0/warmerdam/v0eur/vmaplv0/eurnasia"
  ogrinfo -ro $OGDI -summary  -sql 'select * from "roadl at trans(*)_line" where rtt=14'
  INFO: Open of `gltp:/vrf/grass0/warmerdam/v0eur/vmaplv0/eurnasia'
  using driver `OGDI' successful.
  Layer name: roadl at trans(*)_line
  Geometry: Line String
  Feature Count: 67350
  Extent: (-10.244722, 45.000000) - (90.167747, 70.484337)
  Layer SRS WKT:
  GEOGCS["NAD83",
  f_code: String (5.0)
  acc: Integer (5.0)
  exs: Integer (5.0)
  med: Integer (5.0)
  rtt: Integer (5.0)
  tile_id: Integer (5.0)
  edg_id: Integer (10.0)
  Features are found.
  Somehow Mapserver doesn't get the field names any more for 'LABELITEM'.
Excuse me for asking three questions, but they seem to be closely related.
Kind regards
  Markus Neteler
[1] the Mapfile snippet:
LAYER
 NAME roadl_africa
 GROUP roadl
 TYPE LINE
 CONNECTIONTYPE OGR
 CONNECTION "gltp:/vrf/grass0/warmerdam/v0soa/vmaplv0/soamafr"
 DATA "roadl at trans(*)_line"
 STATUS ON
 CLASS
    EXPRESSION ([rtt] = 14 )
    MAXSCALE 10000000
    SYMBOL "line"
    COLOR 200 20 20
    SIZE 3
    OVERLAYSYMBOL "line"
    OVERLAYCOLOR 250 250 0
    OVERLAYSIZE 1
 END
