[Gdal-dev] GDAL 1.2.0 Solaris build
Frédéric Trastour support at geoimage.fr
Tue Mar 2 10:32:30 EST 2004
Hello,
I am trying to build GDAL with a static link of the Proj4 library.
*** On Solaris, I have the following problem :
My configure line is :
 $ ./configure \
--prefix=$(geolib)/libGDAL_OGR/src/SOLARIS2_6/gdal/RELEASE \
--with-libtiff=$(geolib)/libTIFF/src/SOLARIS2_6  \
--with-geotiff=$(geolib)/libGEOTIFF/src/SOLARIS2_6  \
--with-local=$(geolib)/libHDF/src/SOLARIS  \
--with-threads=-"lposix4 -lnsl" \
--with-hdf4=$(geolib)/libHDF/src/SOLARIS  \
--without-jasper  \
--with-jpeg=internal \
 --with-libz=internal  \
--with-png=internal  \
--without-libtool  \
--without-ld-shared  \
--with-static-proj4=$(geolib)/libPROJ/src/SOLARIS2_6
the libproj.a library is searched in the 'src' directory  under the specified proj directory.
The problem is that when Proj is build with libtool, the src directory doesn't contain
any library. The library is in the ".libs" sub-directory.
Perhaps configure should look directly inside the specified directory ( This allows to
specify either the lib directory resulting of a 'make install' or the '.libs' directory inside
the build tree).
*** On Win32, I specify a static proj link in nmake.opt :
PROJ_FLAGS = -DPROJ_STATIC
PROJ_INCLUDE = -Iz:\GEOIMAGE_SRC\LIBRAIRIES\libPROJ\src\win32\include
PROJ_LIB = z:\GEOIMAGE_SRC\LIBRAIRIES\libPROJ\src\win32\lib
But It looks like PROJ_LIB is never used... I have to add '$PROJ_LIB\proj.lib' to ADD_LIBS
in order to properly link.
Am i missing something ?
Any comments appreciated,
Best regards,
Frédéric.
_________________________________________________________________
Frédéric Trastour - SpacEyes - dev at spaceyes.fr
