[Gdal-dev] optimum overview settings?
Chapman, Martin MChapman at sanz.com
Fri Mar 12 15:53:17 EST 2004
Matt,
Are you using a command line util or the API?
Martin
-----Original Message-----
From: Matt Wilkie [mailto:matt.wilkie at gov.yk.ca]
Sent: Friday, March 12, 2004 1:27 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] optimum overview settings?
Chapman, Martin wrote:
> Matt,
> Also, be aware that if you are writing an ovr file, and an ovr file
> with the same name exists, the gdal lib will append to the file,
> resulting in a file with more ovr's than you expect.  Moral of the
> story...delete the other ovr first.
What happens with geotiffs, where the overviews are embedded?
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
