[Gdal-dev] Re: GDAL with HDF on OSX
    Frank Warmerdam
    warmerdam at pobox.com
    Wed Mar 24 13:57:37 EST 2004
Jeroen Ticheler wrote:
> Hi,
> Thanks for the quick response!
> The location of the package is at:
>  ftp://ftp.ncsa.uiuc.edu/HDF/HDF/HDF4.2r0/bin/macosx
Jeroen,
I tried downloading the HDF4.2r0 for linux and ran into what I presume
are similar problem.  It seems the library uses a function called
"szip_compress_memory" that is not included with the libraries and is
not part of libz or anything else I can find.   I presume it comes from:
   http://www.compressconsult.com/szip/
However, this has gotten quite a bit more complicated than I want to deal
with.  I would suggest that you either:
   Get the HDF4.1r5 package for MacOS and try that.
or
   Submit a bug in the GDAL bugzilla and I will have Andrey look into it when
   he gets a chance.
or
   both.
Best regards,
