[Gdal-dev] Re: GDAL with HDF on OSX
Andrey Kiselev dron at ak4719.spb.edu
Wed Mar 24 16:39:51 EST 2004
On Wed, Mar 24, 2004 at 01:57:37PM -0500, Frank Warmerdam wrote:
> I tried downloading the HDF4.2r0 for linux and ran into what I presume
> are similar problem.  It seems the library uses a function called
> "szip_compress_memory" that is not included with the libraries and is
> not part of libz or anything else I can find.
szip is a non-free additional compression method, used in HDF library.
I'm always recompile libhdf without support for szip.
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
