[Gdal-dev] Problems Linking with Stubs in the precompiled downloadable Win32 Binaries.
Mon May 10 17:32:29 EDT 2004
Fam. Pool wrote:
> Martin,
> Could my problem be that I'm using VC6? I tried compiling from scratch
> and the MSVCRT lib was hassling me all the way to suicidal depression.
> VC7 would be hard for me to acquire tho...
Louis,
I normally build with VC6 myself.  Unless some specific support library
(like JasPer?) requires VC7 you should be fine with VC6.
Best regards,
