[Gdal-dev] gdalwarp
Thu May 13 08:01:06 EDT 2004
Norman Barker wrote:
> Hi,
> thanks for the reply I have run gdalwarp on some geotiffs and it is
> successful, and on others it fails or returns a black image (with a sample
> landsat image).
Norman,
You will need to provide sample images for me to look into this problem.
> Also I have noticed the output of gdalwarp has to be viewed with a proper
> geotiff reader such as Erdas ViewFinder rather than the default tiff readers
> that come with Windows XP?
GDAL by default produces band interleaved (PLANARCONFIG_SEPERATE in TIFF
terminology) files when more than one band is being output.  These may be
unsupported by the WinXP tiff viewer.  You can try adding "-co INTERLEAVE=PIXEL"
if you think this is the problem.
> My question is what do you refer to as a 'properly labelled' geotiff?  Is
> there any more documentation of gdalwarp that I could read, as I said before
> I am a bit new to this, but am very interested!
I mean a file that has coordinate system information (ie. UTM 11 WGS84) *and*
a geotransform (ie. reference point and pixel size).
The gdalwarp utility documentation is at:
   http://www.remotesensing.org/gdal/gdal_utilities.html#gdalwarp
To learn about subtleties of how GDAL warping works, trying reading through
the Warp API tutorial and linked reference documentation:
   http://www.remotesensing.org/gdal/warptut.html
To learn more about the GDAL data model review:
   http://www.remotesensing.org/gdal/gdal_datamodel.html
To learn about characterstics of specific format drivers review their
individual documentation:
   http://www.remotesensing.org/gdal/formats_list.html
Best regards,
