[Gdal-dev] No python support for x86_64 with kakadu?
Alessandro Amici alexamici at fastwebnet.it
Tue Nov 2 14:51:52 EST 2004
Chris,
On Tuesday 02 November 2004 20:14, Alessandro Amici wrote:
> i have only one more possible idea. what is the linking command that builds
> the kadaku shared library? (or even better, you can send me the whole build
> output for the kakadu library. off-list!).
BTW. what distribution do you use? has it full 64 bit userland? can you build
a 32bit version of gdal and run a sort of emulation? do you need full 64 bit
gdal?
(i am looking into setting up a cross build environment)
cheers,
alessandro
