[Gdal-dev] Vector data
Mon Nov 8 13:36:57 EST 2004
William Lyons wrote:
> Hi again list,
> Does GDAL/OGR support any rendering of vector data independent of the
> Python interface?
William,
Nope, none that is part of GDAL/OGR itself.
Some noteworthy renderers built on top of GDAL/OGR include OpenEV and
MapServer.  OpenEV has some rasterization code for polygons that could
be extracted fairly easily.
Also, for an OGR user I am at this very moment (well the moments around
this message) writing a little OGR S57 renderer that uses GD to do the
rendering.  I could provide this as example code if you needed it.
Best regards,
