[Gdal-dev] ERDAS LAN/GIS support in GDAL
DaZoner bdezonia at wisc.edu
Mon Nov 8 15:49:42 EST 2004
I see that I can read ERDAS 7.4 GIS and LAN files using GDAL. But GDAL does
not support writing of this format. Is there a technical reason as to why
this format is not supported for write? (e.g. it supports 4 bit which could
be problematic). Or is it simply a manpower issue.
