[Gdal-dev] problem with warping lat-long to UTM
Norman Barker normanb at comsine.co.uk
Tue Nov 23 09:53:13 EST 2004
I am using gdalwarp to warp an image in Lat Long to UTM.
I am using latlong.tif from ftp.remotesensing.org/samples/pci_eg
and executing the command
gdalwarp -t_srs EPSG:32711 latlong.tif out.tif
but I get the error
ERROR 1: failed to load NAD27-83 correction file
ERROR 1: GDALSuggestedWarpOutput() failed because the passed
transformer failed.
I have seen this discussed before, but there doesn't seem to be an answer I
can use.
Many thanks for any help,
Norman
Norman Barker
Software Engineer
ComSine Ltd
Tel: +44 (0)1483 457121
Web: http://www.comsine.com
*Please Note:*
This text is confidential. If you are not the named addressee, it could be unlawful for you to read, copy, distribute, disclose or use the information contained herewith. If you are not the intended recipient please telephone +44(0)1483 457121.
