[Gdal-dev] Re: can't read netcdf file
wlx wlx at mygis.org
Wed Nov 24 21:18:53 EST 2004
Hi Frank,
     How do I submit a bug report?
     The error message is only one line as I metioned in the previous
email,and may I attach a netcdf file? And you can down it here:
http://debian.mygis.org/hdf/mksrf_soicol_clm2.nc , it is a smallest file
that I have.
     Is Radim's source can directly replace with the current netcdf file?
Maybe I can try it.
     Best regards,
LiangXu Wang
> LiangXu,
> There are definately some problems with the non-GMT netCDF
> support.  Radim provided the changes to support non-GMT
> netCDF files, but he didn't have time to implement full
> support.  If you can submit a bug report with your file I
> will review the situation.  If this turns out to be a common
> problem, and I find I still don't have time to fix up the
> driver I will disable it.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
