[Gdal-dev] reading grass file
Sabine Grabner csab7771 at uibk.ac.at
Tue Sep 7 07:07:55 EDT 2004
hello,
i wrote a method for reading a map with the gdal library which works well for
reading pcidsk-files.
no i tried to read grass maps. i run:
./configure --with-grass=/usr/local/lib
make
make install (as superuser)
when i run my programm i get:
ERROR 4: `/home/sabine/grass/grassdata/oetztal/sabine/dem' does not exist in
the file system, and is not recognised as a supported dataset name.
i suppose i make any simple beginners mistake. do you have an idea how to read
my file?
many thanks, sabine
