[Gdal-dev] GetGeoTransform/png bug?
Kor de Jong k.dejong at geo.uu.nl
Thu Apr 14 04:04:17 EDT 2005
Hi list,
I am using GetGeoTransform, and according to the documentation "The default
transform is (0,1,0,0,0,1) and should be returned even when a CE_Failure
error is returned, such as for formats that don't support transformation to
projection coordinates.". When my application loads a png file
GetGeoTransform returns CE_Failure but the transform coefficients are not set
to (0,1,0,0,0,1). I guess this is a bug in the png driver? As another
example, the GIF driver does return (0,1,0,0,0,1).
I use GDAL 1.2.6.0, released 2005/03/13.
Best regards,
Kor de Jong
