[Gdal-dev] Link errors with Ilwis in MS dotnet SDK
Frank Warmerdam fwarmerdam at gmail.com
Thu Apr 14 09:18:42 EDT 2005
On 4/13/05, Delfos, Jacob <jacob.delfos at maunsell.com> wrote:
> Howard,
> yeah, that's what I did. But like I said, my DLL is now misbehaving a bit. I
> was just wondering whether it had to do with me removing it, since I am not
> sure what it is.
Jacob,
My guess would be that you didn't do a "nmake /f makefile.vc clean"
or that if you did, it didn't work properly.  If ilwis is removed from the list
in frmts/makefile.vc, it should be completely dropped and there should
be no negative effects from this.
What version of VS.Net are you using?  It seems that newer versions
have diverged substantially from VS.Net 2002 which I have, and that
compatibility problems that are hard for me to deal with are coming
up with newer versions.
Best regards,
