[Gdal-dev] GDAL changes affecting GRASS?
William Kyngesburye woklist at kyngchaos.com
Thu Dec 1 16:49:17 EST 2005
Whew!
It's Postgres.  When I leave out Postgres support in GDAL, GRASS
behaves.  It doesn't matter whether I build Postgres support into
GRASS or not, as long as it is in GDAL, parts of GRASS don't like
GDAL (r.in.gdal works, btw).
I'm using Postgres 8.0.4 + PostGIS 1.0.4 right now, but at the time I
noticed the problem it was Postgres 8.0.3 + PostGIS 1.0.3, and I
think I was at Postgres 8.0.3 at a time when it did work, but PostGIS
went thru a few versions (1.0.x).  The only big change I see in there
is adding readline support to Postgres.
(I'll drop this into my bug report also and see if anyone has an idea
now)
On Nov 29, 2005, at 6:55 PM, Frank Warmerdam wrote:
> On 11/29/05, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> I've been having a problem with GRASS lately, and it seems to be
>> related to GDAL.  I have a GRASS bug open for it: #3585.  Noone has
>> provided any help so far.
>> The key trigger combination is: GDAL 1.3.1 (and 1.3.0, possibly the
>> beta), GRASS 6.0/6.1, and built with GCC 3.3 on Mac OS 10.3.  There
>> is no problem building with GCC 4 on Mac OS 10.4, or with GCC 3.3 and
>> GDAL 1.2.6.  Or if I build GRASS without GDAL.  Yes, the GCC 3.3 and
>> GCC 4 builds each have their dependencies built with the
>> corresponding GCC version.
>> The problem is that I get bus errors in a few module - specifically,
>> simple general commands such as g.remove, g.rename and g.copy (but
>> not others, like g.list).
>> So, the question for GDAL - what changed from 1.2.6 to 1.3.x that
>> might affect GRASS this way and only for GCC 3.3-built.
> William,
> I can't think of any obvious reason for this.  I think you will need
> to dig deeper before we can do anything about this.
> Best regards,
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
