[Gdal-dev] Planar Configuration Type 2
Reinaldo Escada Chohfi rec at geodesign.com.br
Fri Dec 2 08:21:13 EST 2005
Julien,
Thanks for the help.  It worked.
Reinaldo
At 06:26 AM 12/2/2005, Julien Demaria wrote:
>Reinaldo,
>You have to use the -co "INTERLEAVE=PIXEL" option of the GTiff gdiver.
>GDAL uses "INTERLEAVE=BAND" by default.
>See here: http://www.gdal.org/frmt_gtiff.html
>Best Regards,
>Julien
>Reinaldo Escada Chohfi a écrit :
>>Hello everyone,
>>Is there any way to make gdal_translate not set planar configuration type
>>2 on a rgb geotif image.  I am running a program that does not like this
>>type of input.
>>Thanks in advance.
>>Reinaldo
>>_______________________________________________
>>Gdal-dev mailing list
>>Gdal-dev at lists.maptools.org
>>http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051202/8c618e24/attachment.html
