[Gdal-dev] OGR Memory leak
Chapman, Martin MChapman at sanz.com
Fri Dec 2 18:08:45 EST 2005
I did some tests with OGR executing queries on a layer with ExecuteSQL()
and found that there is a memory leak occurring when you re-run that
query many times.  I am calling ReleaseResultSet() between each
iteration, and I'm deleting the features objects after I use them.  I
also ran a test that only does the query and doesn't ask for any
features and there was still a leak.  My test consisted of 100
concurrent users (synchronized) over 10000 iterations.  Watching the
private bytes of my process shows a slow but steady growth of memory
allocation with no de-allocation.  When I comment out the call to
ExecuteSQL() the problem goes away.  I also tried to use the GetLayer()
function to retrieve the table followed by calls to SetAttributeFilter()
and the result was less leakage but it still has a leak.  Has anyone
else ran into this problem?  I'm running the test on Windows XP and the
data source is an ESRI shape file with a few hundred records.
The code is like this:
m_pLayer = m_pDataSource->ExecuteSQL(m_sStatement.c_str(), NULL, "");
if (m_pLayer == NULL)
      throw CPLGetLastErrorMsg();
m_pDataSource->ReleaseResultSet(m_pLayer);
m_pLayer = NULL;
// also leaks, but not as much
m_pLayer = m_pDataSource->GetLayer(0);
OGRErr err = m_pLayer->SetAttributeFilter(m_sStatement.c_str());
if (err != OGRERR_NONE) throw CPLGetLastErrorMsg();
err = m_pLayer->SetAttributeFilter(NULL);
Can someone else do a test to confirm that there is truly a leak? ...
Frank? ... anyone? ... Ferris Bueller?
Thanks,
Martin
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051202/b864ea05/attachment.html
