[Gdal-dev] CreateLayer: PostGIS primary key?
Craig Miller craig.miller at spatialminds.com
Fri Dec 2 20:44:33 EST 2005
Is there a way to specify that the FID column should be the primary key when
creating a PostGIS layer with
OGRDatasource::CreateLayer?
Is there any reason why I wouldn't want to use the FID column as the primary
key?
--Craig
