[Gdal-dev] ERDAS IMG .aux file
Reinaldo Escada Chohfi rec at geodesign.com.br
Wed Dec 14 14:24:28 EST 2005
Frank,
The MSVCRT.lib file exists. In the mean time, I would appreciate if you
could build hfatest.exe.  However, I would like to be able to build gdal
due to the fact that am using the gdal utilities more  often and foresee
working with gdal in programming in the near future.
Thanks again,
Reinaldo
At 05:07 PM 12/14/2005, Frank Warmerdam wrote:
>On 12/14/05, Reinaldo Escada Chohfi <rec at geodesign.com.br> wrote:
> >  Hello Frank,
> >  Thanks for the info.  So far I've been using the fwtools.  Now, I tried
> > building gdal for the first time but I got the following error message at
> > the end of the process
> >  C:\Arquivos de programas\Microsoft Visual Studio\VC98\lib\MSVCRT.lib :
> > fatal error LNK1106: invalid file or disk full: cannot seek to
> > 0x35894cc8NMAKE : fatal error U1077: 'link' : return code '0xc'
> >  Stop.
> >  The HD am building on has 42 GB of free space.  Any suggestions on what's
> > going on?
>Reinaldo,
>Does the indicated file exist?
>If you would like, I could prepare a hfatest.exe for you.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051214/f70cd79f/attachment.html
