[Gdal-dev] ERDAS IMG .aux file
Wed Dec 14 15:13:15 EST 2005
On 12/14/05, Reinaldo Escada Chohfi <rec at geodesign.com.br> wrote:
>  Frank,
>  The MSVCRT.lib file exists. In the mean time, I would appreciate if you
> could build hfatest.exe.
Reinaldo,
You can grab:
  http://home.gdal.org/~warmerda/hfatest.zip
The -dt switch means dump a tree view of the file in
question.  The -dd switch will dump a  "data dictionary"
of types defined in the file dictionary.
> However, I would like to be able to build gdal due
> to the fact that am using the gdal utilities more  often and foresee working
> with gdal in programming in the near future.
Sorry ... I'm not sure why things aren't working.
Best regards,
