[Gdal-dev] Problems in the gdal.h file (GDAL 1.3.1 Windows).
Wed Dec 14 18:45:41 EST 2005
On 12/14/05, Mihai Fagadar-Cosma <mihai.fagadar at alcatel.ro> wrote:
> Hello,
> While compiling GDAL 1.3.1, I noticed that there are some more errors in
> the gdal.h file which prevent acces to the RAT data:
> The GDALRATGetColOfUsage function is defined with the 2nd parameter as
> GDALRATFieldType instead of GDALRATFieldUsage.
> The GDALRATGetValueAsXXX functions are missing an int parameter.
> The GDALRATSetValueAsXXX functions are missing two int parameters, on
> the 2nd and 3rd position respectively.
> After correcting them manually I can access the functions.
Mihai,
I believe these problems are fixed up, but I think you
might want to update to the latest nightly snapshot.  If
problems persist let me know.   There have been a
few other RAT related fixes since the 1.3.1 release.
Best regards,
