[Gdal-dev] shaded relief utility
Ethan Alpert ealpert at digitalglobe.com
Fri Dec 16 10:36:36 EST 2005
Does it export closed polygons or pixels or both?
-e
From: gdal-dev-bounces at lists.maptools.org on behalf of Ben Discoe
Sent: Thu 12/15/2005 7:26 PM
To: gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] shaded relief utility
Paul et al.,
The free VTP software (built on top of GDAL) does all this already.  It does
hillshading of existing imagery from a DEM, produces 'color relief maps' by
letting you assign colors to elevations then shading the result.  It also
supports optional shadow casting, from any sun direction.  In fact, in its
3D runtime environment, you can even cast shadows from the terrain onto
terrain, and from culture onto terrain, using accurate sun direction taking
geographic location, time and date into account.
Or you can use it simply in 2D.
http://vterrain.org/
-Ben
> -----Original Message-----
> From: Paul Surgeon
> Sent: Monday, December 12, 2005 10:40 AM
> Compiled easily enough on my Kubuntu Breezy system with "g++
> hillshade.cpp -lgdal -o hillshade" and works perfectly.
> Now I'm just in need of a tool to make color relief maps.
> Maybe I can hack yours.  :)
> Thanks
> Paul
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051216/0307b4f4/attachment.html
