[Gdal-dev] gdal-1.3.1 on FreeBSD 4 fails to build
paul at warriner.us paul at warriner.us
Tue Dec 20 05:03:47 EST 2005
Hope this helps someone, as I have little FreeBSD, C, or C++ background.
It was run on hub.org using FreeBSD 4.11.
I used:
./configure --without-pcraster --with-local=/usr/local
gmake
http://www.warriner.us/gdal-1.3.1-without-pcraster.log
1) gmake warnings
2) results of ./configure --without-pcraster --with-local=/usr/local
3) results of gmake
Results:
# ./gdalinfo --version
GDAL 1.3.1.0, released 2005/10/04
# ./gdalinfo --formats
Supported Formats:
  VRT (rw+): Virtual Raster
  GTiff (rw+): GeoTIFF
  NITF (rw+): National Imagery Transmission Format
  HFA (rw+): Erdas Imagine Images (.img)
  SAR_CEOS (ro): CEOS SAR Image
  CEOS (ro): CEOS Image
  ELAS (rw+): ELAS
  AIG (ro): Arc/Info Binary Grid
  AAIGrid (rw): Arc/Info ASCII Grid
  SDTS (ro): SDTS Raster
  DTED (rw): DTED Elevation Raster
  PNG (rw): Portable Network Graphics
  JPEG (rw): JPEG JFIF
  MEM (rw+): In Memory Raster
  JDEM (ro): Japanese DEM (.mem)
  GIF (rw): Graphics Interchange Format (.gif)
  ESAT (ro): Envisat Image Format
  BSB (ro): Maptech BSB Nautical Charts
  XPM (rw): X11 PixMap Format
  BMP (rw+): MS Windows Device Independent Bitmap
  AirSAR (ro): AirSAR Polarimetric Image
  RS2 (ro): RadarSat 2 XML Product
  PCIDSK (rw+): PCIDSK Database File
  ILWIS (rw+): ILWIS Raster Map
  RIK (ro): Swedish Grid RIK (.rik)
  PNM (rw+): Portable Pixmap Format (netpbm)
  DOQ1 (ro): USGS DOQ (Old Style)
  DOQ2 (ro): USGS DOQ (New Style)
  ENVI (rw+): ENVI .hdr Labelled
  EHdr (rw+): ESRI .hdr Labelled
  PAux (rw+): PCI .aux Labelled
  MFF (rw+): Atlantis MFF Raster
  MFF2 (rw+): Atlantis MFF2 (HKV) Raster
  FujiBAS (ro): Fuji BAS Scanner Image
  GSC (ro): GSC Geogrid
  FAST (ro): EOSAT FAST Format
  BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
  LAN (ro): Erdas .LAN/.GIS
  CPG (ro): Convair PolGASP
  IDA (rw+): Image Data and Analysis
  NDF (ro): NLAPS Data Format
  JPEG2000 (rw): JPEG-2000 part 1 (ISO/IEC 15444-1)
  L1B (ro): NOAA Polar Orbiter Level 1b Data Set
  FIT (rw): FIT Image
  RMF (rw+): Raster Matrix Format
  USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
  GXF (ro): GeoSoft Grid Exchange Format
Regards,
Paul
-----Original Message-----
From: Sam Lawrance [mailto:boris at brooknet.com.au]
Sent: Monday, December 19, 2005 8:50 PM
To: Sam Lawrance
Cc: paul at warriner.us; 'Frank Warmerdam'; 'Benjamin Thelen';
gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] gdal-1.3.1 on FreeBSD 4 fails to build
On 20/12/2005, at 12:37 PM, Sam Lawrance wrote:
> On 20/12/2005, at 10:35 AM, paul at warriner.us wrote:
>> All,
>> The following compiles 1.3.1 on FreeBSD 4.11:
>> I haven't tried GEOS, yet.
>> Yes, Frank, it's my fault for all this, but I sure you guessed
>> that. :)
> Unfortunately the same errors occur:
> http://people.freebsd.org/~lawrance/gdal-1.3.1-without-raster.log
Ooops, correct URL
http://people.freebsd.org/~lawrance/gdal-1.3.1-without-pcraster.log
