[Gdal-dev] RE: GDAL, and C# Access
Paul, Michael michael.paul at tao.es
Thu Dec 22 06:21:24 EST 2005
Hi Frank,
referring to your mail below, effectively there is a way to use GDAL from
within C# without having to use SWIG. I have changed the code you posted to
this list so that it works absolutely stable, both on Windows and Linux with
Mono. You may find it below.
Two rules of thumb in order to make this code working:
1) never define a DLLImport statement with return type string, instead let
it return an IntPtr. Later, you can use the Marshal class to obtain the
string value.
2) always pass a HandleRef to native code, not an IntPtr.
Some notes:
at  http://cvs.sourceforge.net/viewcvs.py/mgis/driver/ogr.MGIS.Data.OGR/OGR/
you may see a more sophisticated wrapper that already permits read-only
access to the OGR C API. They are based upon the classes generated by the
SWIG interfaces of GDAL, but the DllImport statements (ogr_api.cs) have been
changed so that the GDAL library can be used directly.
Last not least: a Managed C++ DLL that exposes the GDAL classes to .Net may
be another approach to solve the problem. An example may be seen in the
following article:
http://www.codeproject.com/csharp/GisMap.asp
Any comments are welcome.
Have fun.
Changed code:
_____________________________
using System;
using System.Runtime.InteropServices;
using System.Windows.Forms;
namespace GoodleWrapper
        public class GoodleWrapper: Form
            private Button button1;
        /// <summary>
		/// The main entry point for the application.
		/// </summary>
		[STAThread]
		static void Main()
            Application.Run(new GoodleWrapper());
		public enum GA_Access
            /// <summary>
            /// Read only (no update access
            /// </summary>
            GA_ReadOnly = 0,
            ///<summary>
            ///Read/write access. */
            ///</summary>
            GA_Update = 1
		[DllImport("gdal13.dll")]
		public static extern IntPtr GDALOpen( [MarshalAs
(UnmanagedType.LPStr)]
                                                string pszFilename,
                                                GA_Access eAccess );
		public static extern IntPtr GDALGetDatasetDriver( HandleRef
GDALDatasetH );
		public static extern void GDALAllRegister();
[DllImport("gdal13.dll",CharSet=CharSet.Ansi,EntryPoint="GDALGetDriverShortN
ame")]
		private static extern IntPtr GDALGetDriverShortName_api(
HandleRef GDALDriverH );
        public string GDALGetDriverShortName(HandleRef GDALDriverH)
            return
Marshal.PtrToStringAnsi(GDALGetDriverShortName_api(GDALDriverH));
EntryPoint="GDALGetDriverLongName")]
        private static extern IntPtr GDALGetDriverLongName_api(HandleRef
GDALDriverH);
        public string GDALGetDriverLongName(HandleRef GDALDriverH)
            return
Marshal.PtrToStringAnsi(GDALGetDriverLongName_api(GDALDriverH));
		public static extern int GDALGetRasterXSize( HandleRef
GDALDatasetH );
            public static extern int GDALGetRasterYSize(HandleRef
GDALDatasetH);
            public static extern int GDALGetRasterCount(HandleRef
GDALDatasetH);
EntryPoint="GDALGetProjectionRef")]
            private static extern IntPtr GDALGetProjectionRef_api(HandleRef
GDALDatasetH);
            public string GDALGetProjectionRef(HandleRef GDALDatasetH)
                return
Marshal.PtrToStringAnsi(GDALGetProjectionRef_api(GDALDatasetH));
		public enum CPLErr
			CE_None = 0,
			CE_Debug = 1,
			CE_Warning = 2,
			CE_Failure = 3,
			CE_Fatal = 4
		public static extern CPLErr GDALGetGeoTransform( HandleRef
GDALDatasetH, [In,Out] double [] Transform );
		public static extern IntPtr GDALGetDriverByName(
[MarshalAs(UnmanagedType.LPStr)]string s );
        GDALCreateCopy(HandleRef GDALDriverH,
[MarshalAs(UnmanagedType.LPStr)] string s, HandleRef GDALDatasetH, int i,
HandleRef j, HandleRef k, HandleRef l);
		public static extern void GDALClose(HandleRef GDALDriverH);
		public static extern void GDALDestroyDriverManager();
		private void button1_Click(object sender, System.EventArgs
e)
			GDALAllRegister();
            	//first rule of thumb: pass a HandleRef to native code, not
an IntPtr.
            	//1. wrap dataset handle return by GDAL into a HandleRef
			HandleRef hDataset = new HandleRef (this, GDALOpen(
"C:\\myimage.tif", GA_Access.GA_ReadOnly));
			if( hDataset.Handle == IntPtr.Zero )
				MessageBox.Show("Could not open Raster
File.");
			HandleRef   hDriver;
			hDriver = new HandleRef (this, GDALGetDatasetDriver(
hDataset ));
			//FW:This seems to wig out .NET...Looks to me GDAL
has become unstable due to this call.
			//second rule of thumb: use Marshal.PtrToStringAnsi
in order to handle strings returned by native code
			MessageBox.Show("Driver: " + GDALGetDriverShortName(
hDriver ) + " " + GDALGetDriverLongName( hDriver ) );
			MessageBox.Show("Size is " + GDALGetRasterXSize(
hDataset ) + " " + GDALGetRasterYSize( hDataset ) + " " +
            GDALGetRasterCount( hDataset ) );
			string ProjectionRef = null;
			//FW:Also this call destabilized the stack. Looks to
me like strings are not handled
			//the way they should be by .NET.
			//Note: applied the rule stated above and code
works:
			ProjectionRef = GDALGetProjectionRef( hDataset );
			if( ProjectionRef != null )
				MessageBox.Show("Projection is " +
ProjectionRef );
			double [] adfGeoTransform = new double[6];
			if( GDALGetGeoTransform( hDataset, adfGeoTransform )
== CPLErr.CE_None )
				MessageBox.Show( "Origin = " +
adfGeoTransform[0] + " " + adfGeoTransform[3] );
				MessageBox.Show( "Pixel Size = " +
adfGeoTransform[1] + " " + adfGeoTransform[5] );
			//Convert to some other format (JPG for example)
			hDriver = new HandleRef (this, GDALGetDriverByName(
"JPEG" ));
			//Do a straight copy.
			HandleRef  hOutDS = new HandleRef (this,
GDALCreateCopy( hDriver, "C:\\myimage.jpg", hDataset,
				0, new HandleRef (null, IntPtr.Zero), new
HandleRef(null, IntPtr.Zero), new HandleRef (null, IntPtr.Zero)));
			if(hOutDS.Handle != IntPtr.Zero)
                GDALClose( hOutDS );
			//Shut everything down.
			GDALClose( hDataset );
			MessageBox.Show("Export to JPEG complete.");
            public GoodleWrapper()
                InitializeComponent();
            private void InitializeComponent()
                this.button1 = new System.Windows.Forms.Button();
                this.SuspendLayout();
                // button1
                this.button1.Location = new System.Drawing.Point(113, 99);
                this.button1.Name = "button1";
                this.button1.Size = new System.Drawing.Size(75, 23);
                this.button1.TabIndex = 0;
                this.button1.Text = "I love &.Net";
                this.button1.UseVisualStyleBackColor = true;
                this.button1.Click += new
System.EventHandler(this.button1_Click);
                // GoodleWrapper
                this.ClientSize = new System.Drawing.Size(292, 266);
                this.Controls.Add(this.button1);
                this.Name = "GoodleWrapper";
                this.ResumeLayout(false);
Regards,
Michael
_____________________________________________
Sent: Thu Nov 4 11:55:45 EST 2004
To: [Gdal-dev]
Subject: GDAL, and C# Access
Folks,
There has been talk from time to time about using GDAL from C# or as a .NET
assemblage.  I can't say I grok all the issues in this area, but I thought
I should pass on something Roger Bedell sent me over a year ago.  He sent
a whole project showing how GDAL could be called from C#, which I am finally
looking at briefly.  I couldn't actually run the project, but I did dig
through the code, and found the following was the core of the GDAL
interaction.
The point is that it is fairly easy to call out to C entry points from C#.
At some point I might well try and maintain an appropriate set of C#
declarations for the GDAL C API though I am not ready to do that just yet.
		/// <summary>
		/// </summary>
		[STAThread]
		static void Main()
			Application.Run(new Form1());
			/*! Read only (no update) access */ GA_ReadOnly = 0,
			/*! Read/write access. */           GA_Update = 1
		[DllImport("gdal11.dll")]
			GDALOpen( string pszFilename, GA_Access eAccess );
			GDALGetDatasetDriver( IntPtr GDALDatasetH );
			GDALAllRegister();
		[DllImport("gdal11.dll",CharSet=CharSet.Ansi)]
		public static extern string
			GDALGetDriverShortName( IntPtr GDALDriverH );
			GDALGetDriverLongName( IntPtr GDALDriverH );
		public static extern int GDALGetRasterXSize( IntPtr
GDALDatasetH );
		public static extern int GDALGetRasterYSize( IntPtr
GDALDatasetH );
		public static extern int GDALGetRasterCount( IntPtr
GDALDatasetH );
		public static extern string GDALGetProjectionRef( IntPtr
GDALDatasetH );
		public enum CPLErr
			CE_None = 0,
			CE_Debug = 1,
			CE_Warning = 2,
			CE_Failure = 3,
			CE_Fatal = 4
		public static extern CPLErr GDALGetGeoTransform( IntPtr
		GDALGetDriverByName( string s );
		GDALCreateCopy( IntPtr GDALDriverH, string s, IntPtr
GDALDatasetH,
						int i, IntPtr j, IntPtr k,
IntPtr l);
			GDALClose( IntPtr GDALDriverH );
e)
			GDALAllRegister();
			IntPtr hDataset = GDALOpen( Application.StartupPath
+ "\\..\\..\\SampleData\\SARA_IRS.TIF", GA_Access.GA_ReadOnly);
			if( hDataset == (IntPtr)null )
File.");
			IntPtr   hDriver;
			hDriver = GDALGetDatasetDriver( hDataset );
			//This seems to wig out .NET...Looks to me GDAL has
//			MessageBox.Show("Driver: " + GDALGetDriverShortName(
//			string ProjectionRef = null;
			//Also this call destabilized the stack. Looks to me
//			ProjectionRef = GDALGetProjectionRef( hDataset );
//			if( ProjectionRef != null )
//				MessageBox.Show("Projection is " +
ProjectionRef );
== CPLErr.CE_None )
			hDriver = GDALGetDriverByName( "JPEG" );
			IntPtr hOutDS = GDALCreateCopy( hDriver,
Application.StartupPath + "\\..\\..\\SampleData\\SARA_IRS.JPG", hDataset,
				0, (IntPtr)null,
				(IntPtr)null, (IntPtr)null);
			if(hOutDS != (IntPtr)null)
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at
pobox.com
