extent calculator / RE: [Gdal-dev] command line stdin/stdout
Rob Cermak cermak at sfos.uaf.edu
Thu Dec 29 18:40:13 EST 2005
If you need a quick calculation and can't get to a command line...
    http://ak.aoos.org/dev/tools/map_extents.php
Rob Cermak : 907-474-7948 : FAX 907-474-7204 : PGP = 0x75869A6E
Alaska Ocean Observing System : Data Management
School of Fisheries and Ocean Sciences : University of Alaska Fairbanks
cermak at sfos.uaf.edu : fnjrc1 at uaf.edu
ED9U1M7P01 at alaska.edu : cermak at alaska.edu
