[Gdal-dev] Building with Visual C++ 2005 Express
Simon Perkins sy at perkins.net
Fri Dec 30 16:03:40 EST 2005
I'm having some problems building GDAL (latest CVS version) on windows
using Visual C++ 2005 Express Edition. I've downloaded and installed the
Platform SDK as suggested by the Microsoft install intructions, but am
running into a missing ATL library problem:
 link /dll /debug /INCLUDE:_OGRFeatureStylePuller  /INCLUDE:_OSRValidate
 /INCLUDE:_OPTGetProjectionMethods  /INCLUDE:_OGR_G_GetPointCount
/INCLUDE:_OGR
RegisterAll /INCLUDE:_GDALSimpleImageWarp at 36
/INCLUDE:_GDALReprojectImage at 48  /
INCLUDE:_GDALComputeMedianCutPCT at 32  /INCLUDE:_GDALDitherRGB2PCT at 28
/INCLUDE:_v
bSafeArrayToPtr at 16  /INCLUDE:_OCTNewCoordinateTransformation at 8
port\*.obj gcore\
*.obj alg\*.obj frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib
ogr\ogr.lib vb6\vb
6_support.obj      odbc32.lib                        gcore\Version.res
/out:gda
l13.dll /implib:gdal_i.lib
Microsoft (R) Incremental Linker Version 8.00.50727.42
Copyright (C) Microsoft Corporation.  All rights reserved.
LINK : fatal error LNK1104: cannot open file 'atlthunk.lib'
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
8\VC\BIN\l
ink.EXE"' : return code '0x450'
Stop.
The library atlthunk.lib doesn't appear to exist anywhere on my machine.
Doing a google search reveals some articles which suggest that the ATL
libraries are not included in visual c++ 2005 express, and that I should
install a full version instead. Discussion at:
http://forums.microsoft.com/msdn/showpost.aspx?postid=64509&siteid=1
(you'll need to log on to the MSDN forum to read this).
Has anyone else had any luck building GDAL with Visual C++ 2005 Express?
The ATL library seems to be only required for some VB6 backwards
compatibility, so is there some easy way of disabling that requirement?
Or am I going to have to shell out for Visual Studio 2005 Standard?
(assuming that includes ATL?) I do also have VS 2003 .NET available, but
I'm also using C# 2.0 (which requires Visual C# 2005) and so I'd rather
not reinstall 2003 unless I really have to.
Cheers,
Simon
