[Gdal-dev] Building with Visual C++ 2005 Express
Simon Perkins sy at perkins.net
Fri Dec 30 18:04:57 EST 2005
Hi Mateusz,
Thanks for the suggestions. I've followed the instructions on that page
and made the required changes to atlbase.h and atlwin.h, and installed
WTL. I then did a complete clean and rebuild of GDAL. However, I get the
same result as with the simple fix I reported earlier: the build no
longer complains about not finding atlthunk.lib, but I get a strange
failure to find MSVCR80.dll when trying to run any of the GDAL utilities
from the command line. Anybody else seen this? I wonder if it is a
"feature" of building win32 applications with visual studio 2005 express?
Cheers,
Sy
Mateusz Łoskot wrote:
>On Fri, Dec 30, 2005 11:02 pm, Simon Perkins wrote:
>>Some updates. I found a suggestion on the web to simply comment out the
>>line #pragma comment(lib, "atlthunk.lib") from the atlbase.h file (found
>>in C:\Program Files\Microsoft Platform SDK\include\atl after you install
>>the platform SDK).
>>Has anyone managed to build GDAL using the express edition of Visual C++
>>2005?
>Have you read my last response?
>Have you tried solution from WTL group I included in my post?
>Cheers
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051230/d18d9443/attachment.html
