[Gdal-dev] Two Level Raster Caches
    Frank Warmerdam
    fwarmerdam at gmail.com
    Thu Feb 17 17:46:22 EST 2005
Folks,
Traditionally GDALRasterBands maintain a block cache.  Internally
this is an array of pointers to GDALRasterBlock objects.  If a block hasn't
been read, the pointer is NULL.
However, for very large images with relatively small tile sizes it is
possible to have *alot* of block pointers to store.  For instance, a
1 million by 1 million image with 64x64 tiles would be 244 million
blocks.  The block pointer array alone for this image would be 1GB.
While this is a pretty big image, I have had real-world performance
issues due to the size of the cache pointer array.
With Peng's encouragement, I have changed to a two-level cache
in some cases.  Basically the first level cache becomes an array
of pointers to secondary grids which are 64x64 blocks.
I have done *some* testing of this change, and committed it today.  It
shouldn't cause any problems, but if folks have an issue please let me
know.
I would add the two level caching only kicks in for images at least
32 blocks wide.
Best regards,
