[Gdal-dev] GDAL and DTEDs
Thom DeCarlo t.r.decarlo at LARC.NASA.GOV
Wed Jan 26 09:19:27 EST 2005
I think there are significant differences when you get to the DTED3,4,5
formats. In particular, I think they use floating point, rather than
integer, data.
But, aren't those higher level products and formats were still classified?
Thom DeCarlo
             Who is General Failure
         and why is he reading my disk?
> -----Original Message-----
> From: gdal-dev-bounces at xserve.flids.com [mailto:gdal-dev-
> bounces at xserve.flids.com] On Behalf Of Frank Warmerdam
> Sent: Wednesday, January 26, 2005 9:10 AM
> To: Stephane Routelous
> Cc: gdal-dev at xserve.flids.com
> Subject: Re: [Gdal-dev] GDAL and DTEDs
> On Wed, 26 Jan 2005 07:49:53 -0500, Stephane Routelous <route at cae.com>
> wrote:
> > Hi,
> > I'm using GDAL, and I need to support reading of DTED data from level 0
> to
> > level 5.
> > According to the doc and code, GDAL only supports reading of level 0,1
> and
> > 2.
> > Would it be possible to add support for DTED data > 2 ?
> Stephane,
> DTED level 0, 1 and 2 are handled without any specific logic for a
> particular
> level.  As far as I know the different levels are just different
> resolutions.  If
> you run into problems with level 4 or 5 and can provide me a sample, I
> would
> be glad to fix it up.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
