[Gdal-dev] gdalsplit error on compile with gdal-1.2.6
Frank Warmerdam fwarmerdam at gmail.com
Wed Jun 15 11:01:11 EDT 2005
On 6/15/05, Marco Vieira <marco_vieira at uk2.net> wrote:
> Hi all:
>    I can compile the Homme Zwaagstra's gdalsplit.cpp with gdal-1.2.0
> without errors, but when I compile with gdal-1.2.6 I got this error:
> gcc -o gdalsplit -L/usr/local/lib -lgdal -I/usr/local/include
> -I/usr/include -ltiff gdalsplit.cpp -Wall
> returns:
> gdalsplit.cpp: In function `CPLErr CopyRasterBand(GDALDataset*, GDALDataset*,
>    int, int, int, int, int)':
> gdalsplit.cpp:237: error: `AddSimpleSource' undeclared (first use this
>    function)
> gdalsplit.cpp:237: error: (Each undeclared identifier is reported only
> once for
>    each function it appears in.)
> Whats happen? The header files appear to be OK.
Marco,
I haven't looked at gdalsplit myself, but I would guess that
it is using the VRTRasterBand.  Relatively recently this
class was altered so that the AddSimpleSource method
is on a subclass, the VRTSourcedRasterBand.  Try to
alter the code to create or cast to this class as appropriate.
Sorry for not being more specific.
Best regards,
