[Gdal-dev] RE: Strange NoData value from a MrSID image (Peng Gao)
Peng Gao pgao at esri.com
Fri Jun 24 13:30:04 EDT 2005
> > If this is 8-bit data, then we should be using
getSampleValueUint8(),
> > not getSampleValueFloat32().
> > The "datatype" in those function name refers to the underlying
datatype
> > of the sample, not the desried return type or such.  I think I even
> > documented that :-)
> Michael,
> Ah!  Thanks, I'll fix that.  This would certainly explain why Peng was
> getting junk values.
> ... I see Andrey has beat me to it.  Thank goodness for CVS reporting
> via IRC.
I have a question about the interpretation of MrSID NoData value.
Is a pixel considered NoData only if all three values match their
corresponding band NoData value, or Is a pixel considered NoData
if any band value matches band NoData value? For example, given
NoData values (0, 0, 0), Are only those pixels with value (0, 0, 0)
considered NoData, or (0, x, x), (0, 0, x), and etc considered
as NoData pixels as well?
Gao, Peng
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050624/1aa43537/attachment.html
