[Gdal-dev] sterea not recognized by gdalwarp
Maciek Sieczka werchowyna at pf.pl
Tue Mar 1 10:40:21 EST 2005
Hi
I want to use the sterea projection with gdalwarp, but it doesn't recognize
the +proj=sterea as a valid option. What's the problem?
[pingwin at localhost etm+24_05_2001]$ gdalwarp -t_srs "+proj=sterea
+lat_0=51.67083333333333 +lon_0=16.67222222222222 +k=0.999800 +x_0=3703000.0
+y_0=5627000.0 +ellps=krass
+towgs84=33.4297,-146.5746,-76.2865,-0.35867,-0.05283,0.84354,-0.8407728
+units=m" p190r024_7p20010524_z33_nn80.tif
u65_sterea_p190r024_7p20010524_z33_nn80.tif
ERROR 1: Translating source or target SRS failed:
+proj=sterea +lat_0=51.67083333333333 +lon_0=16.67222222222222 +k=0.999800
+x_0=3703000.0 +y_0=5627000.0 +ellps=krass
+units=m
The "standard" +proj=stere it works ok. My cs2cs handles both stere and
sterea just ok.
PROJ4 is 4.4.9, built from source, GDAL is CVS-20050215.
Maciek
