[Gdal-dev] NITF and colorinterp
Peng Gao pgao at esri.com
Thu Mar 17 14:37:00 EST 2005
I got the following for gdalinfo -mm
Band 1 Block=640x480 Type=Byte, ColorInterp=YCbCr_Y
  ERROR 6: Unsupported imagery compression format C3 in NITF library.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
  Computed Min/Max=0.000,0.000
Band 2 Block=640x480 Type=Byte, ColorInterp=YCbCr_Cb
Band 3 Block=640x480 Type=Byte, ColorInterp=YCbCr_Cr
What's C3 compression?
> -----Original Message-----
> From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
> Sent: Thursday, March 17, 2005 11:33 AM
> To: Peng Gao
> Cc: GDAL-dev list
> Subject: Re: [Gdal-dev] NITF and colorinterp
> On Thu, 17 Mar 2005 11:16:39 -0800, Peng Gao <pgao at esri.com> wrote:
> > Thanks Frank.
> > Converting to RGB is what I am hoping for. Seems like the
> null pixel block
> > is caused by compression. I can't find compression info. Here is
> > the dump from gdalinfo:
> Peng,
> Dang, I see the GDAL metadata does not include the compression
> code.  I have committed a change to nitfdataset.cpp to
> include reporting
> the IC and IMODE values as metadata.   If the file is JPEG compressed
> you should see it as IC=C8.
> Also, do you not get any error message issued when you get NULL
> back from the GetBlock() call? When I issue "gdalinfo -mm test.ntf"
> on the commandline for a JPEG compressed file I get the following
> message:
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
