[Gdal-dev] NITF and colorinterp
Frank Warmerdam fwarmerdam at gmail.com
Thu Mar 17 14:38:08 EST 2005
On Thu, 17 Mar 2005 11:37:00 -0800, Peng Gao <pgao at esri.com> wrote:
> I got the following for gdalinfo -mm
> Band 1 Block=640x480 Type=Byte, ColorInterp=YCbCr_Y
>   ERROR 6: Unsupported imagery compression format C3 in NITF library.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 0
>   Computed Min/Max=0.000,0.000
Peng,
C3 is plain JPEG compression (as opposed to JPEG2000 which I think
is C8).
Best regards,
