[Gdal-dev] ArcMap overview AUX files
Thu Nov 3 10:24:07 EST 2005
On 11/2/05, Sheykhet, Rostic <rsheykhet at sanz.com> wrote:
> Hi all,
> There appears to be a problem with using ArcMap-created .aux files as
> overviews.
> When I execute the sample test case below, I get an access violation on
> Windows and a segfault on unix.
> This problem has been verified with the
> http://www.gdal.org/dl/data/gtiff/utm.tif file.
> I am attaching the .aux file generated for the utm.tif so that this can
> be tested without ArcMap.
Rostic,
I have verified that this problem is corrected in CVS.
Best regards,
