[Gdal-dev] Google Earth
Chapman, Martin MChapman at sanz.com
Wed Nov 9 12:22:45 EST 2005
Frank,
I installed the application and looked at what dll's they put in their install directory.  I can tell you that they are using gdal12, proj, opengl, the opengl utiltity toolkit, qt, alchemy, xerces, opengl math library, Microsoft win32 api, posix threads, and the windows media library.  Those are the dll's that I could identify easily.  There really wasn't too much more than that though.
Plus, what else are they going to use?  Is there anything better? ...nope.
Best regards,
Martin
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: Wednesday, November 09, 2005 7:23 AM
To: Mateusz Łoskot
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Google Earth
On 11/9/05, Mateusz Łoskot <mateusz at loskot.net> wrote:
> Norman Barker wrote:
> >     -----Original Message in HTML format-----
> >     *From:* gdal-dev-bounces at lists.maptools.org
> >     [mailto:gdal-dev-bounces at lists.maptools.org]*On Behalf Of *Chapman,
> >     Martin
> >     *Sent:* Tuesday, November 08, 2005 8:49 PM
> >     *To:* gdal-dev at lists.maptools.org
> >     *Subject:* [Gdal-dev] Google Earth
> >     I just figured out that Google Earth (a.k.a. Keyhole) uses gdal and
> >     proj.  That is pretty impressive.  Way to go Frank.
> >     Martin
> >     [Norman Barker]
> >     Hi Martin,
> >     don't disbelieve you at all, but how did you work this out?  It
> >     would make an even more convincing argument to my bosses if I could
> >     show them Google Earth as an example!
> Yes, good point. It could be helpful for me too.
Folks,
I am curious why Martin thinks this too, but GDAL has
been used as part of the image processing chain at
Keyhole.  They funded alot of my early work on files larger
than 4GB.
However, it isn't clear to me how significant GDAL is at
Keyhole/Google.
The (weak?) connection between google maps and GDAL has
been my best attempt yet to convince my son I do something
interesting in the basement all day.  But even that seems to
have failed, as he just shrugged.
Best regards,
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
