[Gdal-dev] sterea projection
Wed Nov 9 23:14:52 EST 2005
On 11/9/05, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > gdalwarp -s_srs "+proj=sterea +lat_0=52.15616055555555
> > +lon_0=5.38763888888889 +k=0.999908 +x_0=155000 +y_0=463000
> > +ellps=bessel  +units=m
> > +towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
> > +no_defs +to +proj=latlong +datum=WGS84" -t_srs input.tif output.tif
> > I get an error "Error 1: Translating source or target SRS failed." With
> > "+proj=stere" everything works, but then the transformation is not exact.
> > Is there any way to get these parameters into gdalwarp?
Jan,
I have just committed the changes for bug 980.   If you
were to build from CVS you should get proj=sterea now.
Best regards,
