[Gdal-dev] sterea projection
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Nov 10 10:30:16 EST 2005
Frank Warmerdam wrote:
> Jan,
> I have just committed the changes for bug 980.   If you
> were to build from CVS you should get proj=sterea now.
I built from CVS (version 1.3.1.0) and gdalwarp now accepts "sterea" as
projection. However, the resulting raster is exactly the same as with
"stere". Also, adding the "towgs" parameter doesn't change anything in
both cases. The five calls:
+proj=stere
+proj=sterea
+proj=stere +towgs84=..
+proj=sterea +towgs84=..
+init=epsg:28992
produce exactly the same output.
Jan
