[Gdal-dev] [newbie] Reading of large TIF files
t.laue at web.de t.laue at web.de
Thu Nov 10 03:42:04 EST 2005
Dear all,
I am currently developing a small application using Qt 4 and C++ for handling and
evaluating large aerial images given in TIF / TIFF format. I am using GDAL for image
input. I am working with image overviews and image tiles for providing a good zoom
and pan performance.
At the moment GDALRasterBand::RasterIO is being used for accessing overview levels
and reading small image patchs because I did not find a way how to read from single
overview levels using GDALDataset::RasterIO. Everything is working fine as long as I
am utilising gray value images with one raster band.
In the case of RGB images I can employ a loop for retrieving the data of all three raster
bands from the same overview level resulting in three buffers which contain the data. I
would like to display the color image at the screen but I have no idea how to combine
them again.
Is there a way to create a new dataset for adding the data read from different bands? Is
it possible to use GDALDataset to access single overview levels? Do I have to use
another method independent of GDAL to bring the three buffers together in order to
recreate a RGB image patch? Is anyone working with Qt 4 and GDAL?
I am very thankful for every hint and idea.
Best regards
Thomas
