[Gdal-dev] sterea projection
Thu Nov 10 13:45:35 EST 2005
On 11/10/05, Jan Hartmann <j.l.h.hartmann at uva.nl> wrote:
> Frank,
> No, I'm sorry, I wrote out the complete PROJ-definitions without any
> "init", but adding, changing or leaving out +towgs84=... didn't make any
> difference. The same proj-strings with cs2cs showed the expected
> differences. Doesn't GDAL pick up +towgs84?
Jan,
Yes, it should.  Could you perhaps try processing these
through "testepsg"?  If you give it a PROJ.4 coordinate
system as input it should report various representations,
including what it looks like after going to WKT and then
back to PROJ.4.
Best regards,
