[Gdal-dev] sterea projection
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Nov 10 15:54:39 EST 2005
Frank Warmerdam wrote:
> Yes, it should.  Could you perhaps try processing these
> through "testepsg"?  If you give it a PROJ.4 coordinate
> system as input it should report various representations,
> including what it looks like after going to WKT and then
> back to PROJ.4.
You are right for "testepsg":
- testepsg "+proj=sterea ..."
and
- testepsg "+proj=sterea +towgs84=..."
gives the correct output for the generated proj-strings. The towgs
parameter is present in the second case. "testepsg -t" with a test
coordinate gives correct different results in both cases.
However,
- gdalwarp -s_srs "+proj=sterea..." -t_srs "+proj=longlat..."
and
- gdalwarp -s_srs "+proj=sterea +towgs84=..." -t_srs "+proj=longlat..."
results in two identical output files, both without the towgs84 transform.
Jan
